Magnaflow Direct Fit Cat
Old Mar 11, 2009 | 06:42 PM
Default Magnaflow Direct Fit Cat
Has anyone bought the Magnaflow direct fit cat - part #23405? I'm trying to figure out the pipe diameter and it doesn't seem easy to find. I can get this dirt cheap. Should be a decent downpipe, right?
Old Mar 23, 2009 | 04:32 PM
Well, don't everybody answer at once!
Since nobody had anything to offer on the subject, I went ahead and order one of these. My cost is only $120 Cnd. But it did not work out. I thought Magnaflow was a good namebrand, but this design is **** poor. The problem it that it is not at all designed as illustrated here: http://www.car-sound.com/02product/d...irectfit=23405 The picture seems to illustrate a normal flex pipe, but the one I got used more of a ball joint type socket, which would be fine, but it has an inner sleeve with a 2" diameter. Hard to describe, but bottom line is that this look as restrictive as the OE cat. Maybe more since it is further forward in the exhaust than the ubend - its like having a 2" collector pipe.
Stay away from these. I feel bad for anone who might have bought one of these from an exhaust shop and had it installed, because if you never looked down the neck you'd never know how restrictive this cat is. It would look great installed
Old Mar 23, 2009 | 04:38 PM
RickAKATed10's Avatar
Photobucket
It's unfortunate that you had such bad luck with a great company like Magnaflow. It's too bad no one helped you. I guess no one had any experience with this product so you became the guinea pig. Are you going to continue looking for a better flowing downpipe? I thought ZZP performance (or something like that) sells some quality products.
Old Mar 23, 2009 | 05:30 PM
Yeah, I'm still looking. $120 sure was cheap and convenient. If I'm going to have to spring for more, I'm inclined save a bit and just get headers instead. I was planning on adding a power log. We'll see.
Ironically, the parts store I work for stocks a "economy" direct fit converter that looks pretty good, has u-bend delete. But even that one'll cost me $180. I don't know why the magnaflow was so cheap. Its not because of construction quality or finish. Just bad design.
Old Apr 19, 2009 | 09:11 AM
jbracefan1977's Avatar
wow thats bad.... have you tried contacting magnaflow about this? you see, I have the magnaflow 23405 just installed and I love it so far, they are cheaper on ebay but I wanted a warranty (the salt on the roads here in winter kills an exhaust) so I got it here magnaflow 23405, or you can try one of the vendors here, they are always running sales/specials. either way its a great system and very easy to install... update us if you get to talk to magnaflow or if you get a working flowing downpipe on your car
ShadowX760
Apr 23, 2013 09:25 PM
fwoggybaby
Apr 7, 2012 09:42 AM
rcohen
Mar 15, 2012 11:36 PM
Bob
Oct 19, 2009 03:20 AM
J_Bru_Ha_SS
Aug 4, 2006 03:50 PM
