headers
Old Jun 27, 2007 | 11:00 PM
mcarloss04's Avatar
Default headers
what are some good headers i should get for my 04 ss non supercharged?
Old Jun 28, 2007 | 07:19 AM
wiz kidd's Avatar
Default RE: headers
what mod's do you have done to your car??/
i just ask because i think someone told me that headers dont do anything for you until you hit like 400 hp in these monte's
Old Jun 28, 2007 | 12:02 PM
GrandPaDave's Avatar
Default RE: headers
ORIGINAL: wiz kidd
Right Wiz, headers are designed to tune or time the exhaust pulses to prevent backpressure and give you horsepower on the high end of your rpm's.
Most modern OEM exhaust manifolds/headers are designed to give your torque across the spectrum along with the rest of the engine design.
If you want WOT power for trap speed or making 2000 left hand turns, then you need headers.
So ifyou have a ton of mods to move your torque curve to thehigh end of the spectrum, then header are a plus.
Old Jun 28, 2007 | 01:48 PM
04 Intimidator's Avatar
Default RE: headers
None. You won't want headers on that engine because of the torque loss. If your looking for power drop your money on an entry level turbo kit from ZZPerformance.com or Cartuning.com
Old Jul 20, 2007 | 03:44 PM
ExplosiveSoundz's Avatar
Default RE: headers
wow, took me long enough to find this post.
Why wouldn't he want aftermarket headers on his car? But then for the 3.8 supercharged it is sooo recommended? I dont think I understand...
I have read alot of forum posts where these Supercharger guys rave about them on their 3.8, but then the 3.8 n/a doesnt want to get them on their engines...
Old Jul 25, 2007 | 08:43 PM
Default RE: headers
ORIGINAL: ExplosiveSoundz
The reason is for the loss of lowend torque. The power simply doesn't get applied to the wheels. Once you hit the 300-350 power range you start looking at them. This amount can't be done on a nonblown engine or maybe I should say it would be much less expensive to get the engine blown first as the HP will quickly rise to that arena.
They've also tested the power and there really isn't much a differance with the Cartuning turbo... it seems to be better to get PEMS for their turbo and that is what I would recommend in this case.
Old Jul 26, 2007 | 06:56 AM
Default RE: headers
Great, Thanks for the informative post Dan!
88montessman
Feb 26, 2009 06:37 AM
Artemis Entreri
Jul 12, 2006 06:17 AM
IaMsEpSiS
Jan 17, 2006 10:46 PM
mcarloss04
Sep 14, 2005 04:38 PM
montejass
Aug 16, 2004 04:15 PM
