6th Gen ('00-'05): Does this work?
Given they dont seem to list the 3400, I woudnt think it would be a drop in.
You'd at least know it would fit the car, so you'd be partway there, but youll probably have to adapt the intake side.
The other thing is that the 3400 has an external MAF whereas the 3800 has the MAF built right into the TB housing. It looks like that CAI uses the stock 3800 intake tube, so you may run into the problem that your intake tube + maf is too long and may need to redo the piping completely between the TB and filter to make it work along with potentially adapting for diameter.
6th Gen ('00-'05): Will The 3800 Throttle Body Fit The 3400?
Mastermiller
Feb 27, 2018 05:47 PM
