cold air intake ecm placement?
Old Jul 10, 2013 | 05:05 PM
ecosta221's Avatar
Default cold air intake ecm placement?
hey guys i just bought a Wapon dragon R intake kit for my 03 monte carlo SS 3.8L engine and when i removed the old intake box the ecm was in there and on the paper it says to let it hang around the engine but i dont know where to put it now that the box is removed. should i leave it hanging like it is on the bottom of where the box used to be or is there another solution?
Old Jul 10, 2013 | 07:31 PM
FYI - Unless you have a shielded box around that Weapon-R intake, it's known as a HAI (Hot Air Intake) as it will suck in the air around the engine that has been warmed up.
As for your question about the PCM, I would recommend securing it. Many intake kits, like a Wizaird, come with a method to "strap" the PCM down. Chibiblacksheep is in the middle of some mods with his Monte, as a result he actually mounted the PCM tray from I believe a Blazer (or another GM truck) in the location that the PCM sits in.
Allowing the PCM long term to "flop around", you run the risk of damaging the wiring and/or the PCM.
Old Jul 11, 2013 | 08:17 AM
Mike 00LS's Avatar
I want to say the tray came from a Blazer, too. But in the mean time OP, get some zip ties and just anchor it to something solid. That'll be safe enough until you get a tray or other better means of securing it.
Old Jul 11, 2013 | 09:38 AM
Yep, I used a tray from a blazer.
Also, it doesn't just fit in... I had to drill 2 holes and tap the screws as well.
Old Jul 11, 2013 | 10:42 AM
ecosta221's Avatar
what we actually anded up doing is we cut the factory airbox around the rim of it and drilled 2 holes im the middle and put 3 long zip ties to anchor the PCM to the tray.
seanpeezy
Jan 10, 2016 04:05 PM
Slow_SS
Oct 29, 2012 02:47 PM
siouxcity04montess
Jun 5, 2010 05:49 PM
RickCoMatic
Oct 16, 2008 05:38 AM
Screamin SS
Sep 9, 2005 12:45 PM
