Check Engine Light 2000 SS
Old Oct 15, 2007 | 09:14 PM
MCking1205's Avatar
Default Check Engine Light 2000 SS
Hi everyone i have a 2000 monte SS 3.8L my checj engine light is on and i went to advanced auto parts to get the codes read i just need help on undersanding what it means one code said that "SYSTEM TOO LEAN" which i guess has something to do with the intakes but im not sure so since that what i was tole i jsut dnt know what system to lean means
Old Oct 15, 2007 | 09:40 PM
HyperFox's Avatar
Default RE: Check Engine Light 2000 SS
System too lean... Could be clogged injectors, afaulty fuel pressure regulator, plugged fuel air mixture.
Old Oct 15, 2007 | 09:56 PM
Cowboy6622's Avatar
"system to lean" just means your getting too much air and not enough fuel into engine. to fix this, refer to what hyperfox said.
a "rich" engine is just the opposite: too much fuel, not enough air.
Old Oct 15, 2007 | 10:06 PM
2000LS's Avatar
any work performed on the vehicle just prior to the light coming on?
Old Oct 16, 2007 | 12:42 AM
MCking1205's Avatar
how do i check all of the aforementioned parts such as the fuel regulatory gauge etc...
Old Oct 23, 2007 | 08:15 PM
RocknSS04's Avatar
Sounds like it's time for a can of Seafom fuel injector cleaner, then drive it like you stole it for that tank of gas.
Wayne
http://www.cardomain.com/ride/2319272
hotrodharley
Nov 15, 2013 11:37 AM
J_Bru_Ha_SS
Jul 30, 2007 09:08 PM
billyp35
Feb 1, 2007 08:00 PM
malletboy
May 28, 2006 06:07 PM
rich131
Dec 16, 2005 02:07 AM
