catalytic convertor questions. 2000 Monte ss 3800
Old Mar 15, 2011 | 05:39 AM
JShovinMonteC's Avatar
Default catalytic convertor questions. 2000 Monte ss 3800
I want to get a high flow cat but I can't find if they are bolt on or if any welding an cutting is needed to install the new one/ remove the old one.
Also is it a easy job or how much would I expect to pay a mechanic
Old Mar 15, 2011 | 07:09 AM
If you get a downpipe with a catalytic converter already added to it, then it will be a bolt-in job.
If you just want a new cat, then a shop would cut out the old and put in the new which would require welding.
High-flow cats trip our PCM and set a check engine light.
Old Mar 15, 2011 | 10:39 AM
Here's info about my High Flow Cat swap:
http://crzyz28.sytes.net/mycars/2004..._downpipe.html
Nice and EASY, bolted in perfectly.
RattPack
16
Dec 30, 2015 04:09 PM
Denarius23
Sep 17, 2014 02:18 AM
P343
May 14, 2014 05:21 AM
06-montelt2
Feb 3, 2011 01:25 PM
golfstud2k4
Sep 29, 2010 03:37 PM
