Catalytic converter problem?
and you know what?? if it is the same problem i was having, sometimes youll completely lose your powerband and it will just slowly go through the rpm range. youll feel like your going to blow your motor cause it take so long to get through even 1st gear.
and what else would you reccomend for fixing this instead of seafoam?? Just a new egr??
Best bet would be to pull it off and clean it up (the seat area and the valve and such)- not sure how you would check to make sure its fully closing, although I'd think you'd have a rough idle too (because its supposed to be fully closed at idle and under heavy load)- not sure what would make it close under one case but not the other?
mtwallet
02-25-2007 09:16 PM
