exhaust leak check
Old Apr 6, 2010 | 09:51 PM
Default exhaust leak check
hey ive heard something about running a propane torch (not lit of coarse) along your intake to check for leaks. could someone explain how this is done please, somehting about the rpms will jump?? IDK someone help me out cause im makniig a new CAI and a kinda ram air type deal and i wanna make sure it isnt leaking in unfiltered air. Thanks guys.
Old Apr 6, 2010 | 10:46 PM
mak330's Avatar
what do exhasut leaks have to do with your intake???
what they guy at the muffler shop did to mine was start the car, take a rag and hold it over the tip for a second. i think if theres no leak it stutters, if theres a leak nothing will happen cause there is somewhere for it to go.
im not a mechanic. lol
he really did do the rag thing, but idk what he was looking for.
when you install your intake, make sure to clean the tubing conections with rubbing alcohal. this insures a good seal.
Old Apr 6, 2010 | 10:59 PM
aahhhhhh man LMMFAO im so sorry, the title should be intake leak check awww WTMF sorry guys (pain meds strike again!!)
Old Apr 6, 2010 | 11:15 PM
Enzo354's Avatar
STILL SLOW
Turn your intake tube upwards while its running and pour in dish soap and fill the intake with water from a garden hose/ bucket. Bubbles will come out if there is a leak. Either way you need a new engine.
Old Apr 6, 2010 | 11:20 PM
did that yesterday! now I need a new ingine:p
Old Apr 6, 2010 | 11:26 PM
seiously has anyone ever heard of that propane thing before>
Old Apr 7, 2010 | 01:13 AM
Yes, it is common- take the propane and go around any gasket, seal, or coupler in the intake (kinda hard to test near the filter area though)- the idle will noticeably change if there is a leak and its sucking the propane in. Just keep in mind that propane is heavier than air, so it will sink down. Its not a big deal up on the engine itself as it will just roll down the sides of the engine and to the ground- but over by the filter, you've got to think where the gas is running when it comes out (especially if you're trying to test a piece of vertical piping if your filter is at the bottom).
Old Apr 7, 2010 | 01:20 AM
hey thanks alot man.
MonteSquarlo
Dec 16, 2012 06:18 PM
Overdose666
Mar 19, 2012 09:04 PM
JOETHEPRO
May 27, 2010 02:36 PM
smitty911
Mar 3, 2010 05:11 PM
moonlitmagik
Sep 14, 2009 02:05 AM
