carb rebuild problem
Old Nov 15, 2011 | 11:09 AM
james3757's Avatar
Default carb rebuild problem
i rebuilt a rochester 2bbl carb off my wifes 72 monte. float adjustment was good i put it on it started with no problem and runs beautiful but when the choke opens dies out any ideas
Old Nov 15, 2011 | 11:33 AM
03SSLE's Avatar
It sounds like there is a vacuum leak somewhere. I'd double check all vacuum lines, mounting gasket, etc for leaks. It could also be a fuel metering issue, but I'd check for vacuum leaks first since it is more common of a problem.
Old Nov 16, 2011 | 11:17 AM
james3757's Avatar
Default 72 carb rebuid
i sprayed starter fluid around base plate thats where the leak is so ill reseat it today thanx for the help
Old Nov 16, 2011 | 11:28 AM
03SSLE's Avatar
No problem...glad you were able to find the problem.
Old Nov 16, 2011 | 12:57 PM
james3757's Avatar
Default 72 carb rebuild update
took off the carb put a thin bead of sealer bolted it on and runs perfect. next project is the power steering pump on my 86 monte carlo ss limited edition. thanks again for the guidance, first time rebuilding carb not too bad
Old Nov 16, 2011 | 01:21 PM
03SSLE's Avatar
There's probably some old gasket material of a slight imperfection in one of the mating surfaces if rtv sealer fixed it. I don't recommend using sealer on carb installations. I'd double check the surfaces to insure they are clean and flat. Tighten the carb down using a cross-cross pattern. Don't overtighten or the base of the carb might warp after a few heating/cooling cycles of the engine.
bigdomvegas
Jan 22, 2022 07:22 AM
MySS
Feb 5, 2013 09:33 AM
73monte
Oct 27, 2012 10:38 PM
72 M.C.
Feb 19, 2010 10:03 PM
Ronnie Shephard
Sep 1, 2009 08:16 AM
