Best way to remove
![Question](https://montecarloforum.com/forum/images/icons/icon5.gif)
I want to put headers on my Monte Carlo but its an 86 and still has the stock manifolds from the factory whats a good way to remove them so i can put the headers on the car without snapping any bolts
along with the penetrating oil, i would recommend one of my favorite methods: FIRE!!
heat those bolts up with a torch, then let them cool. do this a few times along with a few whacks with the good ol B-F-H (another favorite of mine). anything that will break the rust will help.
Also i want to put a true dual exhaust any ideas of where to find a good kit? and a friend of mine said to let the motor run for like 10 mins then remove the bolts i dont think that would make it easy to get to the bolts and what if one breaks
as far as dual kits, i'm not sure without doing some googling, since it's a factory single exhaust. a good exhaust shop should be able to make one up for a reasonable price. i know it's recommended that you notch the tranny crossmember on the driver's side for ground clearance or you can buy an aftermarket notched crossmember.
if you do break a bolt, there are bolt extractor kits you can buy pretty much anywhere.
02 Earnhardt Monte Carlo SS
11-10-2011 10:13 AM
