Best way to remove
Old May 9, 2010 | 02:06 AM
86_MONTE_CARLO_CL's Avatar
Question Best way to remove
I want to put headers on my Monte Carlo but its an 86 and still has the stock manifolds from the factory whats a good way to remove them so i can put the headers on the car without snapping any bolts
Old May 9, 2010 | 11:26 PM
Sliver's Avatar
Some of the basics are to soak those bolts with something like PB Blaster or liquid wrench, have a good torch handy (I've had good luck with acetaline), invest in some good six point sockets/wrenches. And most importantly= Luck.
Old May 10, 2010 | 06:10 AM
This cannot be stated strongly enough, especially if they have not been removed in 25 years.
Old May 10, 2010 | 09:08 AM
and not just do it once, spray and soak about 5 times.
I had to do that on some 10 year old exhaust bolts... I couldn't imagine 25 year old bolts.
Old May 10, 2010 | 09:46 PM
drewskie043's Avatar
along with the penetrating oil, i would recommend one of my favorite methods: FIRE!!
heat those bolts up with a torch, then let them cool. do this a few times along with a few whacks with the good ol B-F-H (another favorite of mine). anything that will break the rust will help.
Old May 10, 2010 | 09:59 PM
Also i want to put a true dual exhaust any ideas of where to find a good kit? and a friend of mine said to let the motor run for like 10 mins then remove the bolts i dont think that would make it easy to get to the bolts and what if one breaks
Old May 12, 2010 | 07:24 AM
as far as dual kits, i'm not sure without doing some googling, since it's a factory single exhaust. a good exhaust shop should be able to make one up for a reasonable price. i know it's recommended that you notch the tranny crossmember on the driver's side for ground clearance or you can buy an aftermarket notched crossmember.
if you do break a bolt, there are bolt extractor kits you can buy pretty much anywhere.
02 Earnhardt Monte Carlo SS
Nov 10, 2011 10:13 AM
werewolf-odst
Aug 20, 2011 04:51 PM
Bubbles420
Jun 1, 2010 09:57 PM
monte carlo 3831
Jul 9, 2009 09:03 PM
dirty
Nov 11, 2007 04:13 PM
