YellaJAC is taking it easy!
Old May 12, 2014 | 07:53 AM
JC Colon's Avatar
Default YellaJAC is taking it easy!
Morning MCF. So I fixed the Trans fluid leak at the Trans cooler. The return line was not seated right. So I should have no pressure issues any more. Didn't get to the Electrical work. I started it but then had to do me Husbandly Duties, then Mother's day happened. But I did find that many of the wires in the main harness that are crimped look to be coming apart. So I went to Harbor Freight and got a new Krimper and a But-Ton of 22 - 16 gauge wire connectors. And I have wire. Gonna go through and add 2" of wire to relieve the stress. Hopefully my TCC will work after that and I can finally feel what Ol YellaJAC can do!
Old May 12, 2014 | 11:26 PM
ohara's Avatar
Glad you got the tranny leak fixed, best of luck with the wiring, sounds like you have quite a project on your hands, but in the end it will definitely be worth the effort and time
Old May 13, 2014 | 08:30 AM
03SSLE's Avatar
With all the wiring problems you've been having it might be worth it to just go to the wrecking yard and get a replacement harness.
Old May 13, 2014 | 09:57 AM
Glad you stopped your leak and for your wiring harness use heat shrink over the wire connectors.
Old May 13, 2014 | 11:12 AM
JC Colon's Avatar
Thanks guys, 03SSLE, I may have to replace the harness, It's not pretty and as you said, it has given me so many issues. Maybe go to Harrisburg Pa and pick up all the Little things I need for her!
JC Colon
Jun 8, 2014 04:35 PM
JC Colon
Apr 26, 2014 08:06 PM
Mitchum5543
May 19, 2009 08:50 AM
Yellow_Monte
Sep 26, 2006 06:28 PM
holt
Mar 17, 2005 02:42 PM
