wheel bearing/axel shaft
Old Sep 1, 2010 | 07:29 PM
gohawk72's Avatar
Default wheel bearing/axel shaft
So there has been a humming noise coming from my car when I drive it I thought it was the passenger wheel bearing so I replaced it and it hums a little less what else could the noise be?
Old Sep 1, 2010 | 10:50 PM
is it all the time or just at certain speeds? could be an unbalanced tire
Old Sep 2, 2010 | 12:07 AM
nitehawkjcb's Avatar
Is it when you're turning, or going straight... Or both?
Old Sep 2, 2010 | 06:00 AM
gohawk72's Avatar
You can really hear the noise when I speed up then let off the gas
Old Sep 2, 2010 | 06:29 AM
How many miles on your Monte Carlo ?
Can you try to describe the noise in more detail ?
Is there any vibrations ? Can you pin point the area that it is coming from ?
Check back to see what our expert tech member's will hopefully post to help you...
p.s. sorry to read that you are laid `off...Wish you good luck
4-Sure & I hope one of our great member's can help on your Monte Noise Problem....
Old Sep 3, 2010 | 05:58 AM
gohawk72's Avatar
I think its coming from the front drivers tire area now and there is no vibrations. The car has a 152,000 miles on it. I just think the drivers side wheel bearing is bad too
Old Sep 3, 2010 | 01:57 PM
Could be the wheel bearing, or power steering pump groaning.
Old Sep 12, 2010 | 11:52 AM
christophero1973's Avatar
I had the same problem, wheel bearing.
willie8701
Sep 29, 2010 05:29 PM
Airsin
Nov 6, 2008 11:54 AM
2000_BLACK_SS
Oct 11, 2008 05:22 AM
Yellow_Monte
Jul 11, 2006 10:51 PM
01blackmonte
Oct 17, 2005 07:30 PM
