wheel bearing
Old Sep 16, 2007 | 08:11 AM
willie8701's Avatar
Default wheel bearing
I HAVE A 2001 MONTE DOES IT HAVE A AXLE BEARING AND A HUB BEARING OR JUST A HUB BEARING .
Old Sep 16, 2007 | 08:16 AM
TrickRacin's Avatar
Default RE: wheel bearing
they are one in the same. It is a one piece bearing
Old Sep 17, 2007 | 05:50 AM
willie8701's Avatar
this might be a stupid question but is there a way to lube these.
Old Sep 17, 2007 | 07:00 AM
wiz kidd's Avatar
they're a hub, with abs sensor and they go quiete often on the gms, i think we sell about 5 or 6 a week @ the store here, i dont think there's any way you can lube a hub assembly
Old Sep 17, 2007 | 08:17 AM
willie8701's Avatar
ARE THESE VERY HARD TO REPLACE.
Old Sep 17, 2007 | 08:27 AM
wiz kidd's Avatar
no, should be just 3 bolts to undo and one big nut,and then prying it off...sometimes thats a little difficult to do, but should come off...also NEVER INSTALL HUB WITH AIR GUN! will cause the hub to be defective, and they're not warrantiable if installed with gun
Old Sep 18, 2007 | 04:44 PM
jeffsmonte's Avatar
Oh, so thats probably whats causing my drivers side front wheel to squeek when I speed up. What else can that be, I know its not the breaks...?
Old Sep 18, 2007 | 05:42 PM
TrickRacin's Avatar
ORIGINAL: wiz kidd
Yes, what he said. Always find out the torque sspecs and use em. I have replaced 4 in the last 4 months from people over tightening the axle nut.
Old Sep 18, 2007 | 07:29 PM
04 Intimidator's Avatar
What kind of torque are we talking about on these hubs. I've never done one before and just curious. 45 lbs, 100 lbs?
Old Sep 18, 2007 | 09:50 PM
TrickRacin's Avatar
118 ft. lbs. or (160)nm
