What Wiper Blades is everyone using?
I have installed two different brands of wipers on my 2002 SS and they work great at first but then on the passenger side it skips the center of the blade area when its 1/2 way up the windshield. It only seems to happen in colder weather warmer I never had an issue. Wiper arm tension seems good. I wonder if our cars don't like the beam style wipers and want the old frame style from years past. I also wonder since the wipers park up off the windshield if that makes the beam wipers arch and not want to remain flat when they are turned on. I have used Boshe brand and then some lesser quality beam wipers and still no luck when it's cold. Driver side works fine, no issues with either.
I quite caring about the wiper blades I use on my daily driver. If they fit and clean the window, that is good enough for me. Ultimately, I find cheap ones tend to last about as good as expensive ones (and if they don't, they were cheap enough to not loose sleep about it).
Now, to your point, if I found the blades to "skip" or the life was truly short or some other problem, I would quit using those ones and they go on the "do not fly" list.
I have done blades that were supposed higher quality and allowed you to change the actual rubber blade itself, others claiming about a microedge, the old "dual" blades and a host of others over years of driving. I never found one that I fell in love with to justify the higher cost.
Charleslatrelle
Mar 6, 2015 10:37 AM
jeffsmonte
Mar 9, 2009 04:07 AM
