Well THAT explains the smell
Old May 14, 2010 | 09:12 AM
Overdose666's Avatar
Default Well THAT explains the smell
past week ro so my car has had a slight gasoline smell to it, i figured it was the CAT problems ive been having. Wile lettin it warm up so removing the downpipe would be easier i noticed something.....
this, which my comprehension of warning labels and my sense of smell tell me, is the fuel line, is leaking, bout 2-3 drops every second.... WHY?
Old May 14, 2010 | 09:32 AM
Where is it leaking? From the actual line, or maybe an O-Ring?
Old May 14, 2010 | 09:41 AM
i got a feeling is the o ring, its coming from the connector. Why is it once i decided to fix my car all these problems came up? Any way the connector looks to be intact so i think its the o-ring... or lack there of actualy, when i noticed the leak i shut off the car and disconnected the line, it doesnt look like it ever had a ring on it... but it hasnt had the smell for very long
Old May 14, 2010 | 09:45 AM
Those O-rings do go bad, and I know pulling out the injectors can be a pain.
Buy yourself all new O-Rings, and when you put them on, put some dielectric grease on them so when you put them back in they don't tear.
Old May 14, 2010 | 10:00 AM
any idea of what size they might be?
Old May 14, 2010 | 10:12 AM
I wanna say you'll need 2 O-Rings for each injector... IDK the size
But the FelPro Part # is ES70599
Old May 14, 2010 | 10:17 AM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Idk if this helps but I have also seen where the black plug part that goes down into the fuel rail, if you lean on that or push it to one side, it will leak also, so just make sure that is straight and tight
Old May 14, 2010 | 12:19 PM
what do you mean into the fuel rail? on mine the black part is just clipped on.... did something break?
Old May 14, 2010 | 01:14 PM
MAMONTE's Avatar
I'd say its probably the O-rings too. This happend to my Dads Mustang. One of the O-rings got a tear in it when he changed his spark plugs, and we didn't realize it. So it started leaking gas, replaced ALL the O-rings, on all the injectors, and problem fixed.
04MonteLS
Jun 15, 2010 03:27 PM
ffriccio
Jul 1, 2007 09:06 PM
24_48Fan
Nov 28, 2006 08:25 PM
Scott 41
Oct 21, 2006 02:44 PM
dvick01
Jul 28, 2006 07:18 PM
