Upgrading to S/C...
Old Mar 24, 2008 | 11:05 PM
wroeber_55's Avatar
Default Upgrading to S/C...
I did a search, but I didn't find any topics on this. I was curious as to if I would be able to take a supercharger off maybe an Intimidator, GTP, or an SSEI (maybe from a junk yard?) and put it on my N/A '00 SS. And if I could do that, what would I all need to take from the donor car and put into my car? I also know I would have to upgrade the tranny to handle the extra power, but what all would it need to withstand an S/C, CAI, and exhaust? I was thinking maybe putting in a shift kit and adding an auxiliary trans cooler like Wayne did, but is this enough?
What do you guys think?
Old Mar 24, 2008 | 11:31 PM
rysZ34's Avatar
Default RE: Upgrading to S/C...
I learned that if you want boost, you need to lower compression. The compression ration on an L36 is something like 9.4:1 and the compression ratio on an L67(supercharged) is 8.5:1. You'll need heads, pistons, etc...however, check out this link, ParrotZ34 just boosted his Gen 5 MC Z34:
https://montecarloforum.com/m_84713/tm.htm
Old Mar 24, 2008 | 11:58 PM
Hey Will.
Something to consider. rage772 has got a couple entire supercharged 3800 series II engines for sale in the for sale section. Click the link below for more details in his for sale thread.
S/C 3800 series II engine for sale
Old Mar 25, 2008 | 07:59 AM
wroeber_55's Avatar
Thanks guys, but I don't think I will go that extreme. Changing out the internals or the entire engine will probably get too involved and too expensive; I was just hoping that I would be able to bolt on a S/C without too many changes, but I guess I'll just have to stick with upgrading the intake/exhaust/PCM.
Old Mar 25, 2008 | 11:12 AM
mickey's Avatar
you can just bolt on from what i know of the kit with ZZpref. this is a direct bolt on.
I actually looked at doing this also belive it was like 3,000 when all said and done with the inercooler. and pretty much a direct bolt on.
Old Mar 25, 2008 | 12:03 PM
rj's Avatar
rj
Is this an aftermarket turbo kit Mickey?
I know I've mentioned before how much I'd like my 3.9 in my '06 monte to have the blower on it and other's responded I'd be better off the find an aftemarket turbo to use.
Old Mar 25, 2008 | 01:44 PM
mickey's Avatar
no it is actually a S/C but it was desied as a bolt on with the current comp. etc...
but i know they have a turbo out for the cars also becuse i have actually thought of doing it instead on mine but i cant remeber where the link is for it. I just did a serch on the internet for it .
but the whole kit is pretty kool
Old Mar 25, 2008 | 03:38 PM
wroeber_55's Avatar
As much as I would love to, I don't really have $3,000 to spend on putting a S/C on my Monte. I was thinking more along the lines of going to a junk yard and pulling one out of an Intimidator or GTP or Bonneville and dropping maybe $100-200. So if that's out of the question I will probably just leave my Monte naturally aspirated.
Old Mar 25, 2008 | 06:49 PM
rj's Avatar
rj
I'm sure there's other factors involved besides just dropping a blower on and hitting the streets. If that were the case you'd see alot more guys doing this to their cars.
Like the fuel pump. It will need upgraded or you risk running the engine lean and burning pistons. Then a wiring harness upgrade to take into account things that will get moved around to still be able to operate in their new locations.
Since all cars/trucks now days have flat or dished pistons in them and dished is what you want to run a blower. In therory you could try slapping the blower on your engine and it actually running. But to take full advantage of the power your engine would need to come apart or be replaced with a blower engine.
Old Mar 25, 2008 | 06:54 PM
rj's Avatar
rj
A little info.
When I was in my early 20s a local guy owned a '77 Nova. The car had a 350 small block under the hood. It was a nice car and people liked it. One year for Christmas this guy's sister bought him a blower set up for the car and even paid to have the blower polished. Afterall she wanted her brother's car to look cool.
He ran the 350 like this with the blower on it for a couple years. But the car never really had the power expected out of it. Then one year he took the 350 small block out and had a speed shop put dished pistons in while doing a re-build on it. The car came back out on the streets faster then ever.
So the following year..... the car was tubbed to run bigger tires out back. The tires this guy ran on the cartill then would not hook up. Not with the blower on there. So the car got like 15 inch wheels, 10 inches wide with a set of huge @$$ Mickey Thompson tires on them. With the car being tubbed the tires fit pretty good.
Richardstheman
17
Feb 21, 2009 12:38 PM
wroeber_55
Mar 5, 2008 11:09 PM
White05LT
Dec 16, 2006 09:54 PM
phoenix_iii
Mar 22, 2006 11:00 AM
04MonteLS
Aug 13, 2005 03:14 AM
