Upgrades...... HELP!
Old Sep 6, 2011 | 03:13 PM
06-montelt2's Avatar
Default Upgrades...... HELP!
Ive run out of ideas on what more i can do to my monte performance wise.... Im stumped!!!
Heres a list of what ive done so far.
-Intake
3.5 IN OD 6IN Length pipe that leads to MAF which leads to 3.5" OD spectre 9" length filter with a slim custom fab aluminum airbox.... kinda ghetto airbox but not bad for someone whoes never built one...
-Exhaust
SLP Powerflow catback exhaust system.
-PCM
Tuned PCM from Overkillmotorsports.
Any ideas on what my next attack should be? Any recomendations for modding the current mods i have?
Im looking for performance and im totally at a loss here. All opinions are welcome!
Old Sep 6, 2011 | 03:25 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
To me, it looks like you have reached the limits of what will bolt on. You can have your heads ported/polished and gasket matched... Ummm... IDK.
Have you fixed the tranny problem yet? You may want to consider a shift kit.
Also, a tranny cooler isn't the sexiest mod you can do but it saves $$$ in the long run.
Old Sep 6, 2011 | 03:32 PM
Thanks millermontess! Funny thing about the tranny problems is that they all went away after my whole canned PCM process and not using E-85 because it didnt work with my tune. Yeah the tranny shifts perfectly since the tune/ replacement of the PCM.
So i may not require the shift kit, however the cooler sounds interesting. Can you explain?
Old Sep 6, 2011 | 03:37 PM
Here is a link from another forum. It should help.
http://ls1tech.com/forums/ls4-perfor...must-read.html
The transmission in our cars is notorious for failing. The tranny cooler acts like a radiator for the transmission fluid to keep it cool and prevent premature failure.
EDIT: I know you don't have the LS4, but the transmission is the same.
Old Sep 6, 2011 | 04:47 PM
xxtheshockerxx's Avatar
RED DEVIL
i have a cooler sitting in my room waiting for me to install. There has been alot of ppl on the LS4 forum that run tranny fluid temp of 210-215 before (including me) and after the cooler install they run 160-175. So it seems like a great mod to help out the transmission
Old Sep 6, 2011 | 06:31 PM
kingreyna's Avatar
That's it for that engine that I know. Maybe later we can upgrade to the new Impalas 3.6l 6-spd engine. I think that has 300 hp.
MonteCarlo04SS
Feb 15, 2025 10:41 AM
JCoxx93
Mar 15, 2012 02:14 PM
Saberdicer
Jan 5, 2007 04:51 AM
law65
Jan 1, 2005 02:05 PM
richiep
Nov 12, 2004 12:21 AM
