5th Gen ('95-'99): trim removal
Old Mar 10, 2014 | 03:43 PM
Default trim removal
Does anyone know how the trim that runs under the door from the front wheel to the back comes off? It covers the rocker panel. Already removed the screws and plastic clips but it wont budge.
Old Mar 10, 2014 | 03:46 PM
It may have some sealnt or rust proofing that's holding it in place since you removed all the clips/retainers etc... Other wise, I believe it should pretty much fall off.
Old Mar 10, 2014 | 04:08 PM
Viperpit's Avatar
what stump said is correct. on some models(honda for example) you need to slide them a couple inches forward or back. im not sure what type of retainers are used on the monte but if you go to the dealer and ask to see the clips for the rocker molding you can get an idea of whats holding it on.
Old Mar 10, 2014 | 04:10 PM
Viperpit's Avatar
im guessing the clips on the inside of the molding(not visable to the eye) are holding it on. a clip removal tool can be inserted between the rocker and the molding to get them to let go.
Old Mar 10, 2014 | 06:22 PM
SSemed liked it might have been glued. Just dont want to break it. Will have to try and slide it one way or the other.
gphilpot
Feb 4, 2015 06:58 AM
MonteMoxie
Aug 2, 2011 08:27 PM
BowtiesOnly
Jun 28, 2011 12:46 PM
Fogertyb
Mar 8, 2011 08:12 AM
Pure2sin
Jul 1, 2010 01:36 PM
