sutable substitute for the 200-4R transmission
Old Apr 8, 2020 | 04:47 PM
vitamind's Avatar
Default sutable substitute for the 200-4R transmission
My intentions for this SS restoration is to eliminate as many of the pollution control components as practical. In addition to replacing the factory Quadrajet with an older non-feedback version along with an HEI distributor to eliminate the computer interface, I'm wondering if with everything being removed, I'm going to encounter problems with the lock-up type torque converter in the stock 200-4R. Any advice for these plans in general and specifically, what transmission would be an easy swap that doesn't have the electronic controls? The intention is to keep everything else original, only restored.
Thanks in advance
Old Apr 8, 2020 | 10:27 PM
Steelbizkit's Avatar
700-r4, turbo 350, powerglide.
my choice would be a 700r4. Bout same as turbo 350 but adds overdrive.
https://www.700r4transmissionhq.com/2004r-vs-700r4-differences/
Old Apr 9, 2020 | 06:06 AM
vitamind's Avatar
OK, a 700-R4 it is...and that requires no modifications and I can use the existing drive shaft?
Old Apr 9, 2020 | 09:05 AM
Jeffs02rwdSS's Avatar
If you use a TH400 , 700R4, 4L60 or 4L80 you will need a different driveshaft and crossmember to work.
Old Apr 10, 2020 | 04:26 PM
vitamind's Avatar
Is there any way I can use my 200-4R without the computer?
Old Apr 12, 2020 | 07:08 AM
There is a few companies that make a kit for the 700R4 so I imagine there's something available for the 200-4-R . Have you tried contacting a transmission shop or maybe call summit or Jegs and see if they have the parts. Good luck
ZIPPY02
Jun 7, 2018 06:27 PM
iMuf
Aug 28, 2013 08:15 PM
nick_
Nov 27, 2011 02:29 PM
MC2006
Apr 1, 2011 08:03 PM
batman
Jun 29, 2007 06:04 PM
