suggestions on what to do
Old Dec 22, 2008 | 02:39 PM
turbo monte's Avatar
Default suggestions on what to do
so far i have put on a set of flow master super 40 mufflers and took the cat out, i have a k&n intake, a hypertech chip and msd coil packs. im looking to get more performance out of the car but i dont know what else to do or where to start. can sombody help me?? o and also im not sure on what to program the settings of my chip to if sombody could help me on that also, its a hypertech max energy power programmer.
thanks,
john [/align]
Old Dec 22, 2008 | 03:01 PM
wiz kidd's Avatar
Default RE: suggestions on what to do
did you get rid of the u-bend and the resonator??
Old Dec 22, 2008 | 04:23 PM
no i did not. how do you take the u-bend out with the 02 senser being there? and i was told there wasnt much restriction in the resiniator??
Old Dec 22, 2008 | 04:59 PM
inssanity21's Avatar
there is and you should.
is your montge sc or na? cause if its supercharged then you can go ahead and do a pully swap.
Old Dec 22, 2008 | 05:07 PM
no its not super charged i wish it was. but since it aint i would like to put a turbo setup on it in time. how do you get around the oxygen senser thats in the center of the "U" bend??
Old Dec 22, 2008 | 05:27 PM
kweef's Avatar
well if u would like to do a u bend delete you will need to weld a new 02 bung in the straight pipe that replaces the u bend
Old Dec 22, 2008 | 05:36 PM
o gee. i dont know the first thing about welding or any one that even knows how to weld that i would trust working on my car. is there any other way? if i would buy a whole new down pipe with a u-bend delete does it come with the 02 bung?
Old Dec 22, 2008 | 05:44 PM
mrl390's Avatar
Are you seriously considering buying a whole new downpipe just because you cant find someone to weld in a delete? There are no exhaust shops anywhere around you? Its not a tough job, anyone with a welder and a sawzall can do it.
Old Dec 22, 2008 | 05:50 PM
there is an exhaust shop but i never priced it because i figured they would charge me an arm and a leg.
Old Dec 22, 2008 | 05:52 PM
kweef's Avatar
zzperformance.com i believe sells a u bend delete pipe but its wicked expensive
