suggestions on what to do
so far i have put on a set of flow master super 40 mufflers and took the cat out, i have a k&n intake, a hypertech chip and msd coil packs. im looking to get more performance out of the car but i dont know what else to do or where to start. can sombody help me?? o and also im not sure on what to program the settings of my chip to if sombody could help me on that also, its a hypertech max energy power programmer.
thanks, john [/align] |
RE: suggestions on what to do
did you get rid of the u-bend and the resonator??
no i did not. how do you take the u-bend out with the 02 senser being there? and i was told there wasnt much restriction in the resiniator??
there is and you should.
is your montge sc or na? cause if its supercharged then you can go ahead and do a pully swap. |
no its not super charged i wish it was. but since it aint i would like to put a turbo setup on it in time. how do you get around the oxygen senser thats in the center of the "U" bend??
well if u would like to do a u bend delete you will need to weld a new 02 bung in the straight pipe that replaces the u bend
o gee. i dont know the first thing about welding or any one that even knows how to weld that i would trust working on my car. is there any other way? if i would buy a whole new down pipe with a u-bend delete does it come with the 02 bung?
Are you seriously considering buying a whole new downpipe just because you cant find someone to weld in a delete? There are no exhaust shops anywhere around you? Its not a tough job, anyone with a welder and a sawzall can do it.
there is an exhaust shop but i never priced it because i figured they would charge me an arm and a leg.
zzperformance.com i believe sells a u bend delete pipe but its wicked expensive
