Strut Tower Brace
Old Apr 29, 2014 | 07:48 PM
Griffindor's Avatar
Default Strut Tower Brace
I just recently learned about the strut tower brace. My question is can I take one from a 6th gen and put it on my 5th gen 1998 Monte Carlo Z34?
Old Apr 30, 2014 | 01:11 PM
03SSLE's Avatar
Your best bet would be to find a 6th gen and take length, height, width and bolt center to center measurements. Compare that to the tower to tower measurements of a 5th gen. As long as it isn't too tall or wide there is always a way if there is a will. If brackets aren't available you may be able to drill them into the top of the strut tower.
Old Apr 30, 2014 | 01:41 PM
Crusader SS's Avatar
^this. You might also look into installing one in the rear. I installed mine and it improved the handling noticeably. Same tower strut brace as the front. Good luck and let us know how it turned out.
Old Apr 30, 2014 | 06:30 PM
turbo monte's Avatar
Bmr lists on there Web site the front strut tower brace fits 96-06 monte carlo and the rear fits 97-03 monte carlo but the rear fits an 04 as well as i installed one. IMO bmr is the best stb available
Old Apr 30, 2014 | 09:23 PM
On the 5th gen, you also have to deal with the top plates on the struts.
But, those plates could lend themselves to a little custom fabrication and get what was done here:
Old May 1, 2014 | 06:43 AM
zipper's Avatar
6th gen stb's don't fit 5th gens, so you will need to do some fabricating to make one work. If you don't want to do any fabricating at all, look for an stb from an early 90's Olds Cutlass convertible and take it. Direct fit with no need to fab. That's what I did and it works great.
Old May 1, 2014 | 01:15 PM
Ok good to know. I was just going off of info listed on bmr website was all. Guess bmr website has a typo lol thanks for clearing this up
Old May 1, 2014 | 06:37 PM
l67ss's Avatar
I will be producing BEEFY stbs for 5th gens soon they clear 60* and 3800, unsure of lq1
Old May 20, 2014 | 04:11 PM
anthony_8606's Avatar
Would the rear STB that BMR says only fits thru 2003 (but fits on turbo montes 2004) fit on a 2006?
Old May 22, 2014 | 06:25 PM
Griffindor's Avatar
Great info guys thanks. Where does the rear bar mount though?
