Stb
Stb
does anyone know where to get a stock STB? im not looking to spend a whole lot, im also kind of looking for one in red, i see the one at zzp but it looks a little different than the stock ones on the montes, because the two bolt holes are further apart, any help would be much appreciated, thanks
i am assuming when you say "stock" you mean the GMPP STB? i bought the set of two off gmpartsdirect.com for around $33 shipped. i don't have the part number off hand as i am at work but you could get the PN's at don rome's website www.drcustomparts.com
i would get his STB brackets for a nice clean install also.
Just remember that you have the 3.4 when purchasing your STB. You will need a special bar for alternator clearance.
And stock they are black, so you'll have to paint it.
http://cgi.ebay.com/ebaymotors/Monte...Q5fAccessories
www.drcustomparts.com This guy sells the brackets for the STB (great quality), and also sells some STB's. I am not 100% positive, but I think your Monte (3400) uses the same STB that a 5.3L Monte requires. Both the 3.4L and 5.3L have the alternator in the way, and DRCUSTOMPARTS has an STB that has a "notch" in it for the alternator. He sells it for the 5.3L, but I believe it works for your 3.4L too...You can tell by looking at it that it has the same bend the 3.4L STB's use.
Why its in green, IDK, I just started typing and it was in green....LOL
