Stb
Old Jan 26, 2010 | 10:02 PM
Default Stb
does anyone know where to get a stock STB? im not looking to spend a whole lot, im also kind of looking for one in red, i see the one at zzp but it looks a little different than the stock ones on the montes, because the two bolt holes are further apart, any help would be much appreciated, thanks
Old Jan 27, 2010 | 07:47 AM
drewskie043's Avatar
i am assuming when you say "stock" you mean the GMPP STB? i bought the set of two off gmpartsdirect.com for around $33 shipped. i don't have the part number off hand as i am at work but you could get the PN's at don rome's website www.drcustomparts.com
i would get his STB brackets for a nice clean install also.
Old Jan 27, 2010 | 07:58 AM
Just remember that you have the 3.4 when purchasing your STB. You will need a special bar for alternator clearance.
And stock they are black, so you'll have to paint it.
http://cgi.ebay.com/ebaymotors/Monte...Q5fAccessories
Old Jan 27, 2010 | 08:45 AM
MAMONTE's Avatar
www.drcustomparts.com This guy sells the brackets for the STB (great quality), and also sells some STB's. I am not 100% positive, but I think your Monte (3400) uses the same STB that a 5.3L Monte requires. Both the 3.4L and 5.3L have the alternator in the way, and DRCUSTOMPARTS has an STB that has a "notch" in it for the alternator. He sells it for the 5.3L, but I believe it works for your 3.4L too...You can tell by looking at it that it has the same bend the 3.4L STB's use.
Why its in green, IDK, I just started typing and it was in green....LOL
Old Jan 27, 2010 | 09:37 AM
or for 20 bucks you can have the stock STB with the link I sent :P
Old Jan 27, 2010 | 11:46 AM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
as far as you wanting red, you can always paint them like I did
Old Jan 27, 2010 | 05:35 PM
im gonna paint the one in back red then the two cross ones im getting that will be aluminum
Old Jan 27, 2010 | 07:33 PM
rj's Avatar
rj
So this problem with the ALT being in the way, is this true of the 3.9 engines as well?
MFCL
May 25, 2010 12:06 PM
70monte1
Feb 16, 2010 12:39 PM
Gib DTD
Dec 3, 2009 06:49 PM
