Security
Old Feb 26, 2013 | 06:54 PM
austinlibke's Avatar
Default Security
On my way home. The security light on the dash was on the whole time. No running problems with the car. Just the light was on and stayed on. Any insight to what this may be from?
Old Feb 26, 2013 | 06:55 PM
Oh by the way.. The car is a 95' Monte 3100........ 255K! miles and running like a champ
Old Feb 26, 2013 | 07:03 PM
95 Monte Carlo's are equipped with GM Passkey II. A wire runs from the computer up to the ignition switch and back to the computer (The 2 wires run into the steering column inside an orange shroud. The wire measures resistance from a resistor in the key. If you have a loose connector or if the resistor on the key is worn down... the computer cannot read the correct resistance .,The Chip in your key may be dirty or you might need a new one.
Old Feb 26, 2013 | 09:15 PM
So your saying the more i drive it like this, the more possibility i have it will not start?
Old Feb 27, 2013 | 06:07 AM
aussiek2000's Avatar
It is inevitable that it will not start at one point if you keep driving like this.
Old Mar 6, 2013 | 12:37 PM
So. Little development of the issue. Let the car sit for a few days, starting it every morning i let it sit. The light eventually stopped coming on. Then i drove it a few days again, and now the light it on. Im not saying its not a loose wire or bad key. But could this intermittence be result of some sensor or computer going bad?
Old Mar 6, 2013 | 01:01 PM
03SSLE's Avatar
Try cleaning your key with rubbing alcohol, then do a security relearn:
Turn the key to the ON position and leave it there for 11 minutes.
Turn the key to the OFF position for 10 seconds.
Repeat the above 3 times, then start the car.
If you continue to have problems you'll need to have the system diagnosed to determine the cause of the malfunction.
Old May 31, 2013 | 02:43 PM
mc1978's Avatar
I know this is a slightly older thread, but I stumbled on it as my security light came on yesterday. I did each step in the above post and my car started right away. The light stayed off all day while I ran errands and the car started right up. Thank you 03SSLE for those steps.
Old Jun 6, 2013 | 10:38 PM
crusher38's Avatar
yea mine came on the same day!! lol
i was going home praying it wouldnt just shut off on me. i dont know where to go for a legit key without paying through the nose
enibum
Apr 1, 2007 11:56 PM
keghead40
Jan 7, 2007 03:08 AM
okds650
Sep 20, 2006 04:52 PM
mcarloss04
Feb 16, 2006 05:14 AM
nanahippie
May 25, 2005 05:42 PM
