Quick engine cover question
Anyone know the correct way to put on a 3400 engine cover on so you can still use the oil cap? cant figure it out. took off all the hose straps but still wont fit on snug.
anyone who has done this before and can help that would be great!
thanks alot !
thanks alot !
so there is no way to secure it without the engine cover? also how do you secure the engine cover to the car ?
If I understand your question... On my 3800, I simply grab that extension tube underneath the oil cap and twist about 1/4 turn counterclockwise. It pops out, the cover goes on/off, then I screw the extension tube back in. The base of the tube holds the front of the cover in place. Not sure if the 3400 is the same.
Heres a pic of one installed on another monte if it helps
Does ur oil cap have the extension tube?
Cus I'm pretty ur goin to need it, and I got ahold of one
Pm me
Pm me
What confused me was the engine you have. I thought you had the 3400 engine like in this picture below. Which doesn't have an engine cover. I'm not used to seeing it with a cover on it.
