Quick engine cover question
Old Jun 26, 2011 | 08:19 PM
mistiksky's Avatar
Default Quick engine cover question
Anyone know the correct way to put on a 3400 engine cover on so you can still use the oil cap? cant figure it out. took off all the hose straps but still wont fit on snug.
anyone who has done this before and can help that would be great!
thanks alot !
Old Jun 26, 2011 | 08:43 PM
There's an extension tube that extends the oil area that was on all the vehicles with the covers
Old Jun 26, 2011 | 09:13 PM
3400 or 3800?
The 3800 Series II uses the extention Mitch mentioned. I didn't think the 3400 used an engine cover. Or are you referring to the 3400 in the 5th gen Montes?
Old Jun 26, 2011 | 09:15 PM
Never mind. I just looked at Mitch's pictures. The 3400 does use an engine cover. Mitch is correct. I was wrong.
Old Jun 27, 2011 | 10:05 AM
mistiksky's Avatar
yah its the 3400 engine cover. just bought it and it is not exactly fitting over the engine. its for the same engine the tubing just seems to be in the way.
Old Jun 27, 2011 | 10:11 AM
mistiksky's Avatar
so there is no way to secure it without the engine cover? also how do you secure the engine cover to the car ?
Old Jun 27, 2011 | 10:35 AM
Sparky-88's Avatar
If I understand your question... On my 3800, I simply grab that extension tube underneath the oil cap and twist about 1/4 turn counterclockwise. It pops out, the cover goes on/off, then I screw the extension tube back in. The base of the tube holds the front of the cover in place. Not sure if the 3400 is the same.
Old Jun 27, 2011 | 08:45 PM
mistiksky's Avatar
so what your saying is that i should be able to extend my existing oil cap to compensate for the extra space in between the oil cap threads and the engine?
Old Jun 27, 2011 | 09:24 PM
Franks 03SS's Avatar
2011 Monte Of The Year
Heres a pic of one installed on another monte if it helps
Does ur oil cap have the extension tube?
Cus I'm pretty ur goin to need it, and I got ahold of one
Pm me
Old Jun 27, 2011 | 09:32 PM
What confused me was the engine you have. I thought you had the 3400 engine like in this picture below. Which doesn't have an engine cover. I'm not used to seeing it with a cover on it.
Attached Thumbnails Quick engine cover question-2004-3.4l-v6-la1-w-web-size.jpg
