PSA: Fuses
Old Jul 16, 2025 | 06:58 PM
1st-monte-ls's Avatar
Default PSA: Fuses
https://montecarloforum.com/forum/monte-carlo-repair-help-8/shift-solenoid-codes-63499/
After two years of researching this problem, and being pointed towards potential fixes by some users here, I finally found the possible cause of my car's issues.
Im not here to call anyone out or point fingers (it took me two years to find this) but no one who offered help seemed to know about this fuse. So, to everyone, remember to check your fuses, and remind people to check theirs! Godspeed all!
Old Jul 17, 2025 | 08:38 AM
I disagree. One of the suggestions stated multiple times was to get out the wiring diagram and a multimeter and confirm the electrical is correct. There's only a bit over a dozen wires in the whole harness, so thats not a huge amount of effort.
With a blown fuse, you would've found a wire that should have power/signal that didnt, which would've led you to dig into that wire upstream to find out why - ultimately leading you to the blown fuse. It's basic electrical troubleshooting 101.
Sure, nobody pinpointed the exact issue right out of the gate, but that's practically impossible to do for any problem when you dont have the car in front of you / are going off just a few sentences of info. Hence why we were trying to walk you through the overall diagnostics steps to isolate the problem.
The other thing to keep in mind is that (save for the very rare manufacturing defect) fuses dont just randomly blow on a properly functioning circuit. There's likely something else that caused this to happen / may occur again. It's very likely more diagnostic is still needed here.
Old Jul 17, 2025 | 11:40 AM
I Didn't expect anyone to pinpoint the issue right away, but a lot of people come to the forums to get advice from the older and wiser, to be told "hey dummy, you're overthinking this, there's a fuse you could check first".
​​Not to be led astray needing to test harnesses. Justifying the response of "break out the multimeter" when there's a fuse that could be checked is ridiculous.
But like I said before, no one is being called out here, I just wanted to save a few headaches by reminding everyone that fuses exist and might solve your problem, so don't overlook them. Hopefully this post saves you a headache one day too bumpin.
Old Jul 17, 2025 | 07:41 PM
I have to ask, which fuse panel and which fuse was it (what did GM label it as)?
Old Jul 18, 2025 | 06:54 AM
Nobody here would just say, "check this fuse" and then just be done. A blown fuse is a sign of something bigger, 99% of the time.
Something is happening to cause that fuse to blow. I would check the line or accessories it came from, very closely. -With a multi-meter...
I would bet it going to blow again in the near future if the car is driven regularly.
Old Jul 18, 2025 | 10:18 AM
"Trans Sol"
MonteLSV6
Jan 4, 2014 09:57 AM
USMCdevildog
Dec 17, 2010 09:05 AM
ChevySSGirl
Feb 22, 2009 08:56 AM
chevyrider08
Nov 27, 2008 07:21 PM
nitehwk10
Jul 23, 2008 05:36 PM
