Power Surge
Old Oct 20, 2011 | 12:21 PM
500champ's Avatar
Default Power Surge
I have a 2000 Monte Carlo SS with 164,000 miles on it. Sometimes while driving I get a power surge where the rpm's surge between 1500 and 2200 rpm's. ..I have replaced the fuel filter , plugs and wires and it still does it.Any Ideas as to what might be causing this? When it does it , if I floor it it runs fine , and when it gets past 2200 rpm it runs fine?
Old Oct 20, 2011 | 12:52 PM
Possibly the IAC valve or MAF sensors are getting dirty.
Old Oct 20, 2011 | 06:17 PM
mwjames's Avatar
Did you replace air filter ? anything in your air box/hoses maybe rat nest?
Old Oct 20, 2011 | 10:59 PM
500champ's Avatar
Yes , I changed the oil and Air filter too , didn't see anything that would clog or resrtict the airflow...I will clean the mass air flow senser , and this might sound stupid , but what is the IAC valve and where is it?...Thanks Guys !
Old Oct 20, 2011 | 11:09 PM
NovaSS369's Avatar
Check your grounds! I have had RPM issues linked to a bad trans ground.
Old Oct 21, 2011 | 08:24 AM
IAC is right by the MAF
Old Oct 22, 2011 | 02:57 PM
oneslowmonte's Avatar
IAC= Idle Air Control
squidward
Oct 24, 2023 02:28 PM
jimnles
Jun 28, 2014 05:19 PM
Harleyldraper
Apr 20, 2011 08:27 PM
Harleyldraper
Nov 21, 2010 08:12 AM
itsjustme
Oct 20, 2010 02:37 PM
