PCM problem
just got an ZZP PCM for my 05 s/c monte carlo but I cant get it to turn over. I did everything it said to do but the letting it sit on the on pos for 35mins. did anyone else have a problem or is it just me?
here make it easier for ya
1. Disconnect battery
2. Install new PCM
3. Reconnect battery
4. Put emergency brake on
5. Make sure all doors trunk and hood are closed leave driver window down and reach in through window
6. Try to start. If it doesn't start, leave the key in the on position for 10 minutes
7. Turn off ignition for 3 seconds
8. Try and start the car. It probably won't start. Repeat step 5 two more times.
If this doesn't work disconnect battery for 5 seconds and then try and start the car.
__________________
2. Install new PCM
__________________
Try for a little over 10 minutes, mine was a little difficult to relearn so I waited about 13 or so minutes and I finally got it to start.
