PCM problem
Old Feb 9, 2010 | 04:46 PM
NewFoundJoey's Avatar
Default PCM problem
just got an ZZP PCM for my 05 s/c monte carlo but I cant get it to turn over. I did everything it said to do but the letting it sit on the on pos for 35mins. did anyone else have a problem or is it just me?
Old Feb 9, 2010 | 04:59 PM
theres a whole thread about this like 5 times, look in the new pcm about 3 categories down from this one on the home page
Old Feb 9, 2010 | 05:01 PM
here make it easier for ya
1. Disconnect battery
2. Install new PCM
3. Reconnect battery
4. Put emergency brake on
5. Make sure all doors trunk and hood are closed leave driver window down and reach in through window
6. Try to start. If it doesn't start, leave the key in the on position for 10 minutes
7. Turn off ignition for 3 seconds
8. Try and start the car. It probably won't start. Repeat step 5 two more times.
If this doesn't work disconnect battery for 5 seconds and then try and start the car.
__________________
Old Feb 9, 2010 | 07:17 PM
Try for a little over 10 minutes, mine was a little difficult to relearn so I waited about 13 or so minutes and I finally got it to start.
Old Feb 10, 2010 | 06:43 AM
ZZP has problems with the 05 Monte.
I would call them up right away and let them know it's not working.
panpan
Jun 16, 2014 10:13 AM
The_Maniac
Nov 10, 2010 09:42 AM
nemesis
Dec 26, 2009 05:46 PM
vita
Jun 17, 2008 06:41 PM
