New Lighting
Old Jun 13, 2009 | 04:36 AM
Mitchum5543's Avatar
Default Leds
it wasnt a pack or anything it was 4 individual leds plus the dome light all from the same place all the same model except for the dome of course a differnet size. its weird I cant seem to figure it out ive had some suggestions here and there needs a resistor of some sort just weird that they are still drawing power.
Old Jun 18, 2009 | 11:28 PM
rgant_19's Avatar
I would like to buy new leds for my monte but honestly, I don't know what exact size to get. I just want white as well, nothing exotic.
Old Jun 19, 2009 | 07:09 AM
The Popcorn King's Avatar
FOr the dome light, i used this one.
http://www.oznium.com/rigid-5mm-led-dome
and get the natural white. not the cool white. I think thats what i did cause its a little bluer then the ones that i used in the mirror.
Old Jun 19, 2009 | 08:35 AM
BlackSheep to the rescue!!!
Low Beam Headlight Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3457ALL
Front Turn Signal Light Bulb Size: 3457ALL
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 194
Rear Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 194
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 194
Dome Light Bulb Size: 578
Step/Courtesy Light Bulb Size: 194
Trunk/Cargo Area Light Bulb Size: 912
Old Jun 19, 2009 | 07:06 PM
rgant_19's Avatar
Thanks JJ & Blacksheep for the led info. I call myself buying the right kind of led bulb for my trunk and ask for cool instead of white. Now, at night I can see while the light is on in the trunk but honestly, it don't cover the whole trunk like a regular light bulb would. I just want a light that will last longer of course and I want to change all lights (from headlights, fog lights, brake lights, tail lights and all interior lights) to super bright led lights that I can see with. I even bought the led white tail light bulbs but when I installed them, I had a long pole prop on the brake pedal and the seat for the brake light to come on andcome to find out, it wasn't bright light the regular light bulb. Why, I don't know! LOL
Old Jun 19, 2009 | 08:24 PM
Show off.
Old Jun 26, 2009 | 03:35 AM
1FastMonteCarloLT's Avatar
Does know how to get the dome light off in an 06-07 b/c I was thinking of putting in an LED light in mine as well (Your's looks good too JJ)
Old Jun 26, 2009 | 08:14 AM
Isn't it set up the same way as the 00-05?
If so, you take a small flathead and stick it into the passenger side of the CLEAR cover and gently pry it off from that point. On the driver side of the cover there are 2 clips that stick into the roof, but on the passenger side it has the release point. It's much deeper than it looks, so you'll need a good small screwdriver to pry (I used one from my eyeglass repair kit) Just push in from the passenger side and pull down gently.
Don't pull too hard, you don't want your headliner to come with it.
95monte
Aug 16, 2006 10:02 AM
jcoeracing97
Aug 8, 2006 07:34 PM
litecandy
Jul 19, 2006 07:46 PM
litecandy
Jun 26, 2006 05:13 PM
litecandy
Jun 26, 2006 04:00 PM
