No instrument panel lighting
Old Feb 13, 2006 | 03:55 PM
95monte's Avatar
Default No instrument panel lighting
HI all
Wondering if anyone has run into this problem before, all of a sudden i have no instrument panel lighting, nothing for my speedometer, fuel gauge, or any of the controls for the air, heat..any idea's on where to start, checked the fuse box beside the passenger door, all those fuse's seem fine... any other place I should look for fuse's? I should mention 1995 Monte Carlo LS is the car in question.
Old Feb 13, 2006 | 04:03 PM
debbie's Avatar
Default RE: No instrument panel lighting
Kinda have this same prob. except I have partial lights. One side (passenger side) of my controls for heat and air work, my drivers side is dark. I have partial lights on my instrument panel. I belive it may be a fuse, but there are so many fuse boxes to look at. I looked in my owners manual and there are at least 2 fuse boxes under the hood. It was so complicated, what they called each designation of fuses, that I could figure out which one(s) it might be. I got very frustrated. So, I still only have partial lighting. Also, the fan doesn't seem to blow on 1, it does on all the other settings, I figure it is related to a fuse and the reason the lights are out on my heat/air controls. Good luck.
Old Feb 24, 2006 | 10:05 PM
chevy_jj's Avatar
not to be sarcastic but you didnt by chance turn your dimmer down.
Old Feb 27, 2006 | 03:32 PM
montejass's Avatar
ORIGINAL: chevy_jj
It could also be the dimmer switch itself. Maybe??
Old Aug 16, 2006 | 10:02 AM
debbie's Avatar
The first thing I tried was the dimmer! Still have the problem, just irritating at this point. They tell me it could be a bulb under the dash but I don't think so, not one bulb for all the issues! Doesn't make sense. Thanks for the thought though.
space monkey
Sep 25, 2011 04:17 PM
jreid
Jun 23, 2008 02:12 AM
motoguy1012
Jun 24, 2007 07:41 PM
montejass
FWD Tech Guides '95-'07
Jul 7, 2006 08:44 PM
snacks41
Mar 29, 2005 09:28 PM
