New Headlights, new problem?
Old Apr 17, 2011 | 07:05 PM
Jon's Avatar
Jon
Default New Headlights, new problem?
Ok so i just put in my new headlights a few hours ago and they looked great. but tonight while driving behind my mother, she noticed that one is bright...and the other is not so much. I get out and there is noticeable difference. One blinds you almost to look into, and the other does not. Now could this be just a dull bulb?
I have already checked the connections of the wires.
Any ideas?
Old Apr 17, 2011 | 08:24 PM
jwjones's Avatar
More than likely its not aligned correctly.
Old Apr 17, 2011 | 09:08 PM
Jon's Avatar
Jon
Update: Well i figured out the problem.
The problem is that the angle is off between the lights. one is pointed up higher than the other. so say you are sitting down looking at the lights. you will see one light be bright, now if you get lower you will see that the other light is brighter..
So now i know the problem..not sure how im going to fix it.
Old Apr 17, 2011 | 09:15 PM
There should be adjustment screws on the headlights...
Old Apr 17, 2011 | 09:19 PM
either the alignment screws or else you could have just put the bulb in wrong, make sure it's in all the way.
Old Apr 18, 2011 | 05:21 AM
Jon's Avatar
Jon
i made sure the bulb was in correctly a few times, no change, ill have to look for those allignment screws.
Justin Myers
Sep 19, 2012 08:23 PM
inyanalili
Apr 2, 2012 08:31 AM
scc24540
Sep 6, 2007 09:52 AM
ExplosiveSoundz
23
Aug 2, 2007 11:26 PM
kyle08
Aug 29, 2006 10:43 PM
