6th Gen ('00-'05): Need some measurements for factory sunroof
Old Jun 6, 2020 | 09:22 PM
DAVESS2002's Avatar
Default Need some measurements for factory sunroof
Hi everybody,
Since my Monte died last year I was able to part most of it out and finally got the shell towed away a couple of weeks ago for scrap. But now I want to build a model of my first Monte SS, the 2002 Pace car. I was able to find a 1/24 scale diecast on ebay, but it does not have a sunroof. Before I cut a hole in the roof I want to be able to draw an outline in the correct position. So what I need is for someone to measure their sunroof, and the inches from the front of roof to the sunroof, rear of roof to back of sunroof, and side of sunroof to roof line. I just made a rough sketch of the sunroof on this drawing, if anyone can fill in the actual size for me that would be very helpful.
Thanks
Dave Calhoun
File Type: pdf
Old Jun 13, 2020 | 08:48 AM
RedandBlackSS's Avatar
Hi DaveSS2002:
Has anybody helped you with this yet?
Old Jun 14, 2020 | 10:44 AM
DAVESS2002's Avatar
Originally Posted by RedandBlackSS
Hi DaveSS2002:
no, not yet. Anyone have a tape measure and a pencil?
thanks
Old Jun 14, 2020 | 11:15 AM
OK, headed out to the 2001 now.
Old Jun 14, 2020 | 12:28 PM
Measurements:
The front window rubber is about 3/4" wide.
From front to sunroof (not counting rubber): 8.5"
Side of sunroof to roof line: 3 1/4"
From rear (top edge of window rubber) to sunroof rubber: (not including either rubber) 17 5/8"
Dimensions of sunroof: width (short side) without rubber: 20". Full width with rubber: 21 1/4. Length, without: 32 1/8; with: 33 5/16
Hope that helps.
Old Jun 19, 2020 | 10:51 PM
DAVESS2002's Avatar
Measurements:
Hope that helps.
thank you that is perfect help! Will divide the actual dimensions by 24 to give me the correct size for the 1/24 scale model.
Dave
Old Jun 20, 2020 | 02:26 PM
Good luck with your project... post some pics when you are done.
Chris Iblis
Apr 24, 2018 02:20 PM
Habbibie
Jul 25, 2012 11:04 PM
70monte1
Sep 22, 2011 06:37 AM
demonspeeder1
Mar 24, 2010 06:31 PM
GrandPaDave
Dec 29, 2006 05:12 PM
