Sunroof lube.
Old Sep 21, 2011 | 07:21 PM
70monte1's Avatar
Default Sunroof lube.
Just some information I picked up from the dealer today. I asked what they recommended to lube the sunroof rails and they told me Vasoline.
The service manager said that he found that this works the best and rejects water the best.
I recently relubed mine with white lithium grease. I've tried using this in the past with not very long lasting results.
I came home and cleaned my rails and relubed with the vasoline. The sunroof moved very smoothly. The real test will be how long it lasts. It seems a lot smoother than when I relubed the rails before with the white lithium grease as well as a couple of other types of lubes I have tried.
I just thought I would pass this on for others who might want to lube their sunroof tracks.
Wayne
Old Sep 21, 2011 | 07:26 PM
BigPana's Avatar
Thanks for the info going to have to try it this weekend !
Old Sep 21, 2011 | 07:38 PM
Hmm good to know ive been needing to do that
Old Sep 21, 2011 | 07:42 PM
nickhead's Avatar
silicone lube. in a tube. or dialectric grease. but vaseline is probably cheaper.
Old Sep 22, 2011 | 05:13 AM
70monte1's Avatar
I tried both silicone lube and dialectric grease and they both didn't seem to last very long. It is not to say that the vaseline will but I'm going to give it a try.
It seems like the heat and maybe water has made the other lubes I've tried in the past to turn to an almost liquid form which did not enable the sunroof to go very smoothly.
Wayne
Old Sep 22, 2011 | 06:37 AM
03SSLE's Avatar
When I lubed mine I used white lithium grease, but I'll have to give Vasoline a try and see if it lasts longer. Thanks for the tip!
ladyvyxen
Jan 14, 2013 08:28 AM
Tadcaster
Aug 8, 2011 03:16 PM
ckerdflag
Jun 1, 2007 09:59 AM
makenzie71
Aug 29, 2005 04:24 PM
big green dog
Apr 25, 2005 04:06 PM
