Installing CD player in 2002...need wiring diagram!!!
Old May 22, 2007 | 03:57 PM
PuppetMaster's Avatar
Default Installing CD player in 2002...need wiring diagram!!!
Hey all. I bought a alpine head unit online and the site I bought it from sends free installation accessories with the cd player. I got the dash install kit with it, and the antenna adapter, but I didn't recieve a wiring harness...so I decided to try to find a stock wiring diagram for my 02 so I can just cut into the wires and call it good....however, I have hooked up the power and ground and the cd player will NOT turn on. So if someone could find me a wiring diagram, that would be awesome...thanks
Old May 22, 2007 | 04:16 PM
scc24540's Avatar
Default RE: Installing CD player in 2002...need wiring diagram!!!
that was a big mistake, on these new cars if u dont do it just right you're gonna mess something up. it is a very good idea that you just go ahead and buy a harness from walmart or somewhere and do it that way.
Old May 22, 2007 | 04:43 PM
well i've already started, so if your not gonna help, there is no reason to reply
Old May 22, 2007 | 04:56 PM
scc24540's Avatar
just trying to stop you before you screw your wiring system up and have to pay someone a ridiculous amount of money to fix your screw up.
Old May 22, 2007 | 05:27 PM
well I appreciate that and all, but I have confidence that I won't mess it up...
Old May 23, 2007 | 03:35 PM
SSNY's Avatar
Radio 12v
orange
radio harness
Radio Ground
black
radio harness
Radio Ignition
(Class 2 Serial Data)
Radio Illumination
gray (dimmer)
radio harness
Factory Amp Turn-on
same as power antenna wire
Power Antenna
white
radio harness
LF Speaker +/-
tan - gray
radio harness
Notes: If equipped, the amplifier is under the rear deck.
RF Speaker +/-
lt. green - dk. green
radio harness
LR Speaker +/-
brown - yellow
radio harness
RR Speaker +/-
dk. blue - lt. blue
radio harness
for the igniton you will have to go to ignition wires , the wire will be a thick pink wire coming out of the key cylinder harness, make sure you run a in line fuse along with it a 10 amp will be fine.
Old May 26, 2007 | 01:25 PM
so when you say ignition, you mean the switched 12v source? correct?
matt210
Dec 7, 2018 09:21 PM
mrcmos
Nov 20, 2011 11:36 AM
Herlsy
Apr 1, 2011 11:11 AM
78 Monte
Jun 23, 2009 09:32 PM
X Jon X
Mar 10, 2007 12:20 AM
