need some help!
Old Oct 7, 2011 | 03:54 PM
Boxman420's Avatar
Default need some help!
well my monte seems to have a "that time of the month" section were crap just goes wrong.. and its frustrating. my check engine light came on about 2 days ago and is still on right now. so i pulled the code today after work with a OBII scanner. and i got a P0446 its a evap failure or malfunction.. what should i look at replacing??
Old Oct 7, 2011 | 04:59 PM
03SSLE's Avatar
Did you gas up recently? It could be a loose gas cap. It could also be a restriction in the tank vent, or a malfunctioning vent valve.
Old Oct 7, 2011 | 05:39 PM
Boxman420's Avatar
i did gas up like 90 miles ago and i checked the gas cap its on good... i changed my fuel pump a few months back and had a small ishue with the fuel pressure sensor on top, but managed to get it to work. now is this part the same thing?
Old Oct 7, 2011 | 06:48 PM
03SSLE's Avatar
The vent valve is #22 in the diagram below. A bad eletrical connection or valve could cause a P0446 code. An obstruction in any of the hoses leading to the canister or a plugged canister itself could also throw that code.
MCSS06
May 29, 2015 08:04 AM
blackmonte781
Oct 3, 2011 01:38 PM
nebstewart07
Jun 19, 2009 08:38 AM
mickey
Aug 23, 2006 05:31 PM
Puppet Master
Aug 15, 2006 07:44 PM
