Major wiring issues. NEED HELP!!
Old Jan 25, 2010 | 10:54 PM
ianbmxr's Avatar
Question Major wiring issues. NEED HELP!!
I just bought a 2000 monte carlo from a friend that had it sitting in his garage. It was running and I went to check the trans fluid since it seems to be shifting a little hard, and when I went to put the dip stick back in I got a shock from where the dip stick sits. I tried 2 more times and wasnt able becaue I kept getting shocked. I eventually turned the car off and and put it back in. I was wondering why I got a shock from it? And also when it is at lower rpms it shows as if the alternator is going but I replaced that and I still have problems of it seeming to not have enough power. Any advice will be greatly appriciated. Thanks
Old Jan 25, 2010 | 11:17 PM
maybe the plug wires are bad and your getting the shock because the trans stick is close to the plug wires and it was running at the same time? just a guess from me? you may also need a new battery? I'm not 100% sure, hopefully another member will be able to help! by the way, welcome the forum, when you get a chance tell us more about your monte and put up some pics. hope you get it figured out.
Old Jan 26, 2010 | 08:37 AM
ianbmxr's Avatar
I looked at the wires last night and I found out that there is a small arc of electricity coming from what looks like part of my firewall and going into a tubr coming from it. I am going to try and wrap the tube in electrical tape till a certified mechanic can look at it. Im not sure what is grounding into what the arc is coming from but thanks for the help. If I wouldnt have looked there I wouldnt have seen it since its in the same area.
BeachBumMike
Apr 29, 2014 08:27 AM
MRagland828
Oct 30, 2012 09:30 PM
cstoots
Feb 19, 2012 09:55 AM
dustybird3
Apr 19, 2011 09:39 PM
86montecarloooSS
Aug 16, 2006 03:50 PM
