lifting the rear with a jack
Old Oct 21, 2009 | 12:10 AM
jimbo7's Avatar
Default lifting the rear with a jack
this may sound really dumb, but where is the best place to put a jack to lift the rear of my monte? i put it on the sub-frame "rail" a few inches from where the fuel filter is and it caved in. i about pooped my pants when i went to put the jack stands underneath an noticed it all dented in. sometimes i jack fwd cars where the lower control arm meets the frame, but these cars don't seem to have a good place to jack up the rear.
Old Oct 21, 2009 | 01:32 AM
Frosty LS1's Avatar
Lmao @ pooping your pants, that really made me laugh. But I don't know dude, not sure if you can jack it up from the rear. You can always back the Monte up onto ramps, right? Same thing, but safer.
Old Oct 21, 2009 | 06:21 AM
labnjab's Avatar
The body pinch weld or subframe is where I usually jack it. Most cars that I put on the lift at work are lifted from the pinch weld as well. In most cases you can't get the lift arms to the subframe in the rear, either a gas tank or somethings in the way
I can't believe the sub frame would have been damaged, unless it was rotted. Their usually very tough
Old Oct 21, 2009 | 10:08 AM
jimbo7's Avatar
i guess i need some ramps then
i'll post a pic to show what i'm talking about
Old Oct 21, 2009 | 11:46 AM
rj's Avatar
rj
How easily can you get under your car?
I use the spot between both back wheels to jack either the '03 or '06 Montes when I want both back wheels off the ground at the same time.
You'll see a spot in the middle that looks beefier and curves down towards the ground. That's where I place a 4x4 piece of wood. (i just typed weed) lol
Use the wood to help the floor jack cradle reach the car easier. Cause the exhaust is in the way.
Old Oct 21, 2009 | 02:07 PM
MAMONTE's Avatar
X2 on what RJ said. I do the samething with the 4x4.
nemesis
Nov 2, 2013 12:22 AM
Shandley
Jul 28, 2010 10:55 AM
Absolutpolack
Sep 9, 2009 07:15 PM
chaosking881
Jan 25, 2008 12:23 PM
01BlkSS
Jan 22, 2007 12:48 PM
