L67 swap done!!
Old Feb 18, 2013 | 07:18 AM
Dam20735's Avatar
Default L67 swap done!!
Ok I finally finished my swap an started my car it's ran ruff so I then cut it off let it sit for a day came back put coolant in it an wanted to figure out what else was wrong with it but in doing that my car cut off an I went to start it back up an now only the flywheel will turn does anybody know what the problem might be
Old Feb 18, 2013 | 08:34 AM
What did you do for the swap?
Old Feb 18, 2013 | 12:07 PM
nitehawkjcb's Avatar
Did you change the PCM? Unplug the MAF, check for CEL/SES codes.
Old Feb 18, 2013 | 01:19 PM
Dam20735's Avatar
i went supercharger an i turn the key annuffin else happens but just the flywheel spins thats it an the pcm was tuned at zzp
Old Feb 18, 2013 | 01:56 PM
Did you do any security relearn procedures for the PCM?
Old Feb 18, 2013 | 06:21 PM
Check for codes? Bad crank sensor?
z34phoenix
33
Oct 9, 2013 09:16 PM
MONTE2000SS
May 11, 2012 05:38 AM
Cowboy6622
Dec 15, 2007 10:40 AM
chgs15
Feb 2, 2007 05:02 AM
roadshoptuner
Aug 2, 2006 12:53 AM
