Who has done the top swap
Old Apr 6, 2012 | 10:43 PM
MONTE2000SS's Avatar
Question Who has done the top swap
I am going to the yard tomorrow and when I come home I need some help on this top swap computer part....I am tryn to find out the detail on what needs to be modded for this supercharger to work on my car ....I pretty much know all the parts I will need but don't know nothing about the computers please fill me in so I can get my car SUPERCHARGED then on to my next mod which i don't know what will be next after I unlock all these new mods with this I figured I can talk to the people if I find out who on here has successfully done this and what problems will I run into...thanks guys
Old Apr 6, 2012 | 11:19 PM
Enzo354's Avatar
STILL SLOW
You will need someone with a tuner program to rewrite some of the files. Either have zzp send you a top swap pcm, or get it tuned yourself. You need to mix files, and it helps to have all of the files on hand from a gtp. I'm running most of the GTP info in mine, with the stock tranny settings left in it.
Old Apr 6, 2012 | 11:47 PM
Ok so get the computer out of this grand prix I'm getting everything from ....how about plugging all this new stuff in and whatbaout boost
Old Apr 7, 2012 | 12:14 AM
Enzo354's Avatar
STILL SLOW
No, you want to get the info from a GTP or a supercharged monte, not the computer.
Old Apr 7, 2012 | 01:56 PM
So I don't need a computer at all...I could only find Buick 98 with supercharger it should still be the sae though right
Old Apr 7, 2012 | 06:17 PM
bump ....i need some help here!!!!! i found buick supercharger ..what gets plugged into map sensor i dont have that plugged
Old Apr 7, 2012 | 10:33 PM
Enzo354's Avatar
STILL SLOW
Find a write up on Grandprixforums.com You need a lot more then the supercharger.
Old Apr 7, 2012 | 10:58 PM
Yes I know what I need for most part didn't have enough time to pull the heads and then woman at crazy rays junkyard tried to charge me 140.00 for tensioner pulley and bracket and for two valve covers....but yet I got the supercharger and intake manifold for 115.00 for both so go figure how did she come up with that is beside me but I need to know how this map sensor hooks up and what harness adaptors I would need to do this job
Old Apr 7, 2012 | 11:55 PM
Enzo354's Avatar
STILL SLOW
The map is hooked up by another wire you need to get. I think zzp sells the wiring kit.
Old May 11, 2012 | 05:10 AM
Explicit_Spade's Avatar
I don't know how much different montes are from prixs, but on my 04 prix, I used the stock map sensor wiring. I then plugged the map sensor directly to the nipple on the LIM under the snout.
