Keyfob works irradically
Old Feb 11, 2012 | 05:44 PM
Alan Johnson's Avatar
Default Keyfob works irradically
Help--my 2000 Monte SS often does not lock or unlock using the 4 button wireless keyfob. Have two--both have new batteries and both have been programmed via my Monte radio. Once reprogrammed they work fine for a day--then begin to lock or unlock inconsistently. Seems that pressing a command near passenger headlight sometimes works when other areas near car don't. Also, alarm always works. Help!
Old Feb 11, 2012 | 08:32 PM
Hi Alan. Had you not mentioned you already changed the batteries, I'd say it sounds like the batteries are low. Is it possible the battery you put in might have sat around for a long time?
Hopefully others will chime in with similar experiences.
Old Feb 11, 2012 | 08:34 PM
I'd agree with this
also, what's the age on the fobs? the older they get the less the buttons work, it's the rubber that wears, when i got new fobs the rubber made it work 10x better before, and that was on the same stock battery
Old Feb 12, 2012 | 03:25 AM
One of mine had a similar problem and one of the solder joints on the battery contact was broken. I re-soldered it and it's been fine since.
Old Feb 12, 2012 | 04:41 AM
Enzo354's Avatar
STILL SLOW
I had the same problem.
AND I THREW IT ON THE GROUND!!
No really, I did. My girlfriend gave me a pretty weird look, considering how nice it looked from me painting it.
Old Feb 12, 2012 | 08:07 AM
Could try taking it apart, clean the contacts with rubbing alcohol and inspect the solder connections in it.
Old Feb 21, 2012 | 07:35 PM
Default thanks!!!!!!!!!!!!!
followed your advice(s)--cleaned contacts with q tip and rubbing alcohol---solved problem--------Thank you(s)!!!!!!!!!!!!!!!!!!!!!!!!!!!:thumbs up:
wvmonte01
Nov 29, 2011 09:44 PM
yfz450man
Jul 24, 2011 02:21 AM
monte07
Feb 22, 2011 09:28 AM
monte07
Mar 26, 2010 09:43 PM
04MonteLS
Jun 18, 2005 11:22 PM
