Instrument Cluster interchangeable
Old Dec 2, 2010 | 10:30 AM
tj4ndirish's Avatar
Default Instrument Cluster interchangeable
Does anyone know if the instrument clusters are interchangeable? I have a 2005 LS with just the 4 gauges and would like to change to a 6 gauge cluster.
Also, will the mileage have to be reprogrammed?
Thanks.
Old Dec 2, 2010 | 10:32 AM
You can interchange the clusters, however one of the gauges won't work, I forget which one, but I think it might be the oil pressure gauge.
You have to have the mileage reprogrammed, and you have to sign a legal document saying that you performed the switch and at what mileage.
Old Dec 2, 2010 | 01:19 PM
05MonteLS's Avatar
Huh, I thought you had to have the PCM from the 3.8 Liter engine in order to get the SS gauge cluster to work..
Old Dec 2, 2010 | 01:47 PM
Nope, all the gauges won't work, but you don't need the PCM, it picks up from other sensors
Old Jun 1, 2011 | 10:09 AM
mairj40's Avatar
You don't have to change the speed sensor or anything since the SS cluster goes to 140mph and the LS only goes to 120?
Old Jun 1, 2011 | 11:54 AM
Franks 03SS's Avatar
2011 Monte Of The Year
nope, all gauges work as they should, except the oil one like chibi said
Old Jun 1, 2011 | 12:29 PM
I know it's a little different, but I swapped my guage cluster on my '94 Grand Am years ago. I got one close to my mileage (and waited for my mileage to catch up). I managed to get the upgraded cluster from another v6 Grand Am. All I had to change was the oil pressure switch to a sending unit. After that ALL the guages work perfectly fine.
You might need to do a similiar swap to make the SS cluster work 100% on your car.
Old Jun 1, 2011 | 01:09 PM
Budsjlm's Avatar
mitch (trewyn15) has done it on his LS if i remember right
Old Jun 1, 2011 | 05:00 PM
yeah i did!
YouTube - ‪New Gauge Cluster Test-red04montels-HD‬‏
like they said the oil won't work, and i was wrong in the video, the volts is in the correct place.
the only bad thing is you need to test the stepper motors to make sure they won't fail later and you need to get the mileage transfered.
mileage can be transfered at bbengineer.com and just run the car for a bit to make sure the motors are working.
Monte SSV
Jan 24, 2009 02:12 PM
SSOOCH
Dec 8, 2008 10:45 AM
natedawg0613
Jul 25, 2007 09:45 PM
InTheIROC
Feb 7, 2007 11:47 PM
