How much will a Cold Air Intake Help
Old May 13, 2012 | 08:33 PM
16With01MonteSS's Avatar
Default How much will a Cold Air Intake Help
With my 6th gen. Monte carlo 2001 Ss will it increase Acceleration help with gas millage give me the sucking sound and everything they are suppose to do? Also what brand and whats the reason for that brand let me know! please looking to mod my cars performance now thank you in advance!
Old May 13, 2012 | 10:03 PM
plter's Avatar
If it's one that's mounted in the lower front fender well. it sucks water into the motor and seizes it up by bending the connecting rods when you hit a deep puddle in the road.
You get about the same performance by just installing a K&N filter in the stock air cleaner.
If you are going to put a high flow exhaust with headers, a radical cam, larger injectors and high pressure fuel pump, Chipped ECU etc. you might then benefit from a larger intake system and filter.
Old May 13, 2012 | 10:16 PM
Wrong on pretty much everything said.......
read this and you'll be way better than what was said above.......
Bill from Cold Air Inductions Inc. saying hello!! ( 123 ... Last Page)
Bill @ CAI Inc
Old May 13, 2012 | 10:31 PM
zipper's Avatar
Plainly speaking, you're looking about about a 5hp gain and if you can keep your foot off the pedal, another mile or two per gallon. With that said, gains are negligible between brands and you'll see a nearly identical gain with a home built fwi.
seanpeezy
Jan 10, 2016 04:05 PM
toddsmontess
Jan 6, 2012 09:44 PM
siouxcity04montess
Jun 5, 2010 05:49 PM
schroederdion
Jun 29, 2006 09:16 AM
01blackmonte
Aug 24, 2005 08:21 PM
