- How many `miles on your Monte Carlo + Problems ?
Old May 5, 2013 | 09:31 PM
  #261
milrlyt's Avatar
93.5k - replaced oil pan gasket (been bad for about 25k), power steering pressure line hose (bad for 15k maybe), and new suspension (was old but still ok).
Did some other stuff but was just routine maintenance.
Wheel hubs coming up soon.
Old May 6, 2013 | 06:40 AM
  #262
03SSLE's Avatar
Originally Posted by owens91
lets see im at 96600, and my abs is on which makes me think i have a hub assembly issue, transmission slips i think (idk if im going crazy or not) and im having poor gas mileage (15.70mpg)kinda need help with that issue
If your transmission is slipping that could explain the poor mpg.
Old May 6, 2013 | 09:35 AM
  #263
owens91's Avatar
I also figured that. I gotts wait to save up tho, I pjt some lucas trans slip fix in it and that slowed down the process
Old May 6, 2013 | 12:13 PM
  #264
owens91's Avatar
Old May 17, 2013 | 11:07 AM
  #265
Monte_Man04's Avatar
2004 Monte Carlo SS N/A @ 100,000 Miles, I've owned it since 60,000.
1. Needs new front hubs
2. (possibly) needs new bearings
3. Needs rust repair in the rear passenger wheel well
4. Needs new stepper motors for the gauges in the cluster
5. Needs new struts
6. Could use a new set of tires.
I try to do all the work on my own. The rust issue I need to get to a shop before the winter comes. The salt they put down here in Michigan is murder.
Old May 17, 2013 | 01:45 PM
  #266
JAFO's Avatar
Traded car with 126,256. Was due for front end alignment or L/F hub and a new set of tires. Besides that the only maintenance was normal wear & tear. (plugs, wires, serp belt, oil changes, trans filter, pads & rotors) All in all a very reliable and enjoyable car, I will miss it
Old May 23, 2013 | 12:38 PM
  #267
4th-3v0's Avatar
Hi everyone...01 Monte ss 3.8 147000...was replacing the lower control arm bushings...passenger side first...done...went to driver side and the bushing was upside down or opposite the one in the passenger side control arm...Is this the correct way they should be placed or are they supposed to be the same way....
Old May 23, 2013 | 04:08 PM
  #268
owens91's Avatar
i might not have to get a rebuid, i looked at the dipstick and it looks a bit dirty, what i did was add some more tranny fluid and its been feeling better, i think i just need to do a filter and fluid change
Old May 23, 2013 | 07:54 PM
  #269
Barovelli's Avatar
Originally Posted by Barovelli
Waited until today to reply.
Bought it in April with 55,000 on the clock. Today it hit 85,000. 30,000 comfy, safe miles this year.
Update. 140,000 today. That's about 35,000 after the engine was replaced with a 60,000 mile donor.
Replaced starter. Replaced thermostat. Rear defogger works now, solution was in the forum.
Trans shows signs of pending failure - back out of a parking place, shift to drive and get a hard launch or a shudder. But its been doing it since about 90K. Change fluid more often than I ever did in hopes of putting off complete doom.
Right front speaker no longer plays radio sounds, just a high pitched noise that follows the RPMs.
Yet reliable. Commute is 75 miles a day, has not let me down.
Old May 23, 2013 | 09:56 PM
  #270
mine turned 71,000 a week ago........
