6th Gen ('00-'05): How to fix the outside temperature sensor?
Old Jul 28, 2014 | 11:34 AM
00MonteCarloSS's Avatar
Default How to fix the outside temperature sensor?
How do I go about fixing the outside temperature sensor in my car? There is something really wrong with it, most times it reads between 20 and 35 degrees when it is actually close to 90 degrees outside here most days. Sometimes, after driving for awhile, it snaps out of it and works fine, then a few miles down the road or after I shut it off and leave it for awhile, it starts doing it all over again.
How can this be fixed?
Old Jul 28, 2014 | 12:31 PM
In front of the radiator behind the bumper is where the sensor sits. You can try to replace it?
Old Jul 28, 2014 | 08:23 PM
That's weird, I figured it would be near the rearview mirror somewhere. Can it be replaced you think?
Old Jul 28, 2014 | 08:28 PM
Yes it can be replaced. A simple plug and play item. Look for this item by your latch area... Before you but one, see if the existing connector is not fouled from oils, radiator coolant etc. Look for frayed wires or poor connection.
Standard SMP AX67 Ambient Air Temperature Sensor Buick Cadillac Chevrolet | eBay
Old Jul 31, 2014 | 11:15 PM
Ok, thanks, guys! Will look at it tomorrow when I can see outside.
Old Aug 6, 2014 | 01:26 PM
I found it, ordered in the new part, should be here by morning!
avendo
Dec 19, 2014 05:40 AM
doorkid09
Jun 7, 2011 08:39 PM
stringbander
Nov 9, 2009 09:41 PM
1984LCMonte
Aug 14, 2009 05:54 PM
hckygoalie31
Nov 15, 2006 10:35 PM
