outside temp sensor
Old Dec 3, 2014 | 09:16 AM
avendo's Avatar
Default outside temp sensor
Any reason why mine says 140F I reset the compass thing...
Old Dec 3, 2014 | 10:17 AM
Maybe it's broke ? Needs cleaned (Maybe ?), dust & dirt gets into everything & prevents them from working correctly.
Hopefully one of our Super tech member's knows (?) or a member that has had this problem with their temp sensor ? Do you know where the sensor is located ?
Keep checking back... Good Luck!
AMBIENT AIR TEMPERATURE GAGE SENSOR REPLACEMENT
REMOVAL PROCEDURE
You may not even have to lift the car, but you should be able to see it on the front baffle by the radiator support
  • Raise and suitably support the vehicle. Refer to Vehicle Lifting.
  • Disconnect the electrical connector from the ambient temperature sensor that is located on the front radiator air baffle.
  • Remove the ambient temperature sensor from the radiator air baffle.
INSTALLATION PROCEDURE
  • Install the ambient temperature sensor to the radiator air baffle.
  • Connect the electrical connector to the ambient temperature sensor.
  • Lower the vehicle.
  • Drive the vehicle at a speed of 32 km/h (20 mph) for approximately 1 1/2 minutes or at a speed of 72 km/h (45 mph) for approximately 1 minute in order to obtain the ambient update.
Old Dec 3, 2014 | 10:22 AM
Old Dec 3, 2014 | 10:44 AM
You may need a new sensor. They look pretty simple to change out. You can probably get one for cheap or at a junk yard.
Old Dec 3, 2014 | 10:45 AM
Great Find Space!
Looks like you have it covered!
Thanks!
Old Dec 3, 2014 | 08:22 PM
avendo's Avatar
cool I will check it out,so many little problems with this car and I just got the thing,my Bonneville had a lot less..monte needs steering shaft greased and replacing it..dorman has a recal on the part replacement..
Old Dec 19, 2014 | 05:40 AM
avendo's Avatar
got new one,ac delco at rock auto for 7 bucks...all is well now.
maxxpro123
Nov 13, 2014 07:59 PM
00MonteCarloSS
Aug 6, 2014 01:26 PM
farmerjg
Feb 7, 2013 10:05 PM
clidem64
Jun 10, 2012 11:08 PM
smolek37k
Dec 1, 2007 07:08 PM
