Heated seats
Old Feb 10, 2012 | 08:53 PM
plokm24's Avatar
Default Heated seats
I have a 2000 monte carlo ss, is it possible to get heated seats in it? It have leather seats with a bunch of vent holes in it, but i do not have a switch in the car for it.
Old Feb 11, 2012 | 08:09 AM
I guess your going where none of us has gone before.
I would check with a local auto upholstery shop. Seams it would be possible to me
Old Feb 11, 2012 | 08:28 AM
Mike 00LS's Avatar
I'm planning on attempting this myself. You should have the wire harness underneath the seats - all you'll need to do is get the switches and install them in the filler spot in the console.
Old Feb 11, 2012 | 02:58 PM
here is a kit that is pretty affordable. I would like to add these to my back seats sometime. Universal Heated Pad Kit 1 Seat(4 Pads) Heater Car Truck SUV(3-Way LED Switch) | eBay
Old Feb 11, 2012 | 03:27 PM
SupplySgt's Avatar
I doubt the seats have the heating pads in there. The heat pads are installed between the foam and seat cover. I highly doubt GM would have ordered a heated leather only to install it in a car without the heater switch. What I would do is find the wiring harness for a heated seat and compare it to your current wiring harness. That will tell you pretty quickly which wires are for the heat. Once you know that you can take that wiring harness and integrate it in. Grab some switches and install it in your console, make sure you have the appropriate relays and everything is grounded correctly and then once you install the heated seats all you do is plug it in.
The key would be to be very deliberate and make sure you wire everything up right. It can be done though. I know people who have wired in heated power seats from newer cars into classic cars. I'm actually looking into doing that in my 73 Camaro.
Old Feb 11, 2012 | 04:16 PM
I'll have heated rears soon
Old Feb 12, 2012 | 06:05 AM
Mike 00LS's Avatar
I misread. I thought the OP said he was swapping in factory heated seats, in which case it would be plug and play.
seawolf18
Nov 10, 2013 10:23 AM
MrChyes
22
Jul 24, 2011 10:59 PM
SolowSS
Mar 19, 2009 07:41 PM
dustybird3
Apr 25, 2008 08:56 PM
phlyx
Dec 16, 2005 02:10 AM
